Pin Changes for 87 camaro
Old Nov 8, 2000 | 12:26 AM
Tad's Avatar
Tad
I have 87 camaro that was a LG4. Installing TPI and need to know what wires have to be move on the two plugs that connect to the interior harness. I am using a engine harness out of 87 Trans Am. It also has a small six pin gray plug on it what was it for.
Old Nov 8, 2000 | 03:44 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
It is for the power from the fuse panel for the inj1 and inj2 fuses. There's a bunch more wires needed besides those. I made a drawing do you want a e-mail copy?
Also read this thread, it's short.
https://www.thirdgen.org/messgboard/...ML/000308.html
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
http://64.176.105.239/octride.htm
Old Nov 8, 2000 | 10:53 PM
Tad's Avatar
Tad
Yes I would like the drawing it would be very much appreciated and any other advice you have. tadkim@dstream.net
thanks.
Old Nov 9, 2000 | 05:43 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Heh, its a challenge. John knows what I went through. I used a Painless Wiring wiring harness, and it is a very "primitive" setup. I had to basiclly do the entire wiring harness by hand, from behind the dash, to every sensor under the hood. I have seen what John has, and it is exactly what you need to do.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N, S/D TPI retrofit including functional PassKey, 22# injectors, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Nov 10, 2000 | 07:43 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Hey John, Is there any way I can get you to send that info to me, too? I've been seriously thinking about doing this myself, but, I'm not too sure about it. I have the experience and technical background to do it, but never thought about all the extra wiring that needs ran (INJ fuses, etc)
TIA
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Starting to look like the Kicker poster child!
Old Nov 10, 2000 | 10:26 PM
Engine: 4.0L
TIA
Well, I can't send it to you due to you have no e-mail listed.
So here you are.
http://www.geocities.com/millicanga/TpiWiring.jpg
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
89GTAOz
May 16, 2020 09:31 AM
383backinblack
Aug 15, 2015 06:36 PM
bryan623
Aug 10, 2015 11:33 AM
