91-92 Dash lighting
Old Nov 11, 2000 | 08:06 PM
nicksL98's Avatar
91-92 Dash lighting
Ok .. How is the lighting set up in the dash of 91-92 cars? Is it fiberoptics or bulbs/optics or what? In my car the right side of the dash (tach, volts, etc) works, but the left side does not light up (speedo , fuel, etc). The gauges all function , but no lights on the drivers side. Can anyone help me? It would be nice to see how fast im going
Thanks,
Nick
Old Nov 11, 2000 | 08:40 PM
turbo497's Avatar
remove cluster and replace bulbs. we are also working on group discount for white faced gauges abd high output xeon blubs check post for white faced guages. this would be a good time to upgrade
Old Nov 12, 2000 | 04:58 PM
nicksL98's Avatar
Do i have to remove the whole cluster from the dash assembly or can i just pull off the dashpad and get at the bulbs from there?
Also, is there just one bulb in the HVAC controls too? that one is burnt out too.( i think)
Old Nov 12, 2000 | 05:09 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You have replaceable bulbs in the insturment panel. Just remove the cluster (leave the dash pad on) and you will see all the bulb sockets, they twist in. You probably have a bad bulb.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims.
'97 Bonneville SSE
LittleFranks
Sep 17, 2015 12:22 PM
Pilotrick50
Sep 2, 2015 12:48 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
