1 1/2" gauges
Old Nov 9, 2000 | 06:38 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
1 1/2" gauges
Does anyone know where I can get a 1 1/2" electric 0-100psi fuel pressure gauge?
I looked all over the web. I am out of ideas.
[b]86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm[b]
Old Nov 10, 2000 | 07:23 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
All I've been able to find in that size is a mechanical gauge.
Tim
Old Nov 10, 2000 | 04:41 PM
Engine: 4.0L
Tim
That's better then nothing. Can you please send me the info about a mechanical 1 1/2"
fuel pressure gauge? I will just have to use an isolator to use it inside the car.
Oh, and it needs to read 0-100psi.
86 Camaro Sport
Old Nov 12, 2000 | 06:52 PM
Engine: 4.0L
top
Old Nov 12, 2000 | 08:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Here's a mechanical one, not necessarily the only one on the market:
http://www.holley.com/HiOctn/ProdLin...OS/gauge2.html
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
[This message has been edited by Apeiron (edited November 12, 2000).]
Old Nov 12, 2000 | 09:20 PM
Engine: 4.0L
Thank you, thank you very much.
86 Camaro Sport
Old Nov 12, 2000 | 10:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any time. I'm also looking for fuel and nitrous gauges right now that don't look too out of place with my existing gauges and I came across these.
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
gord327
Sep 29, 2015 10:18 PM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
