Blinker
Old Nov 9, 2000 | 01:45 PM
WhiteLightning's Avatar
Blinker
I have this wierd problem. At night when I go to turn on my lights, my left blinker (the little arrow inside the car) begins to go on, sometimes it slowly blinks other times it comes on for a while very brightly.
Old Nov 9, 2000 | 02:44 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Sounds like a sign of the flasher unit starting to go bad.
KAM
Old Nov 10, 2000 | 07:19 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If this happens only when you turn on the running or head lights, then the problem is probably an intermittant open ground going to either the front or rear left hand turn bulb socket.
Tim
Old Nov 10, 2000 | 11:51 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
To check the flasher, turn on the hazard lights and see if they flash normally.
If they do, then switch the flasher relays. They should be the same, and you really dont need a good hazard flasher.
Also, check the bulbs.. Bulbs are the cause of lots of stupid problems....
Later!,
Daniel
Old Nov 14, 2000 | 07:52 AM
The hazard flasher is not the same as the turn signal flasher. The turn signal flasher has a current sensative heater element in it that will not flash if a bulb is burned out to indicate a fault.
Tim
Old Nov 16, 2000 | 06:40 PM
Ok, So now I know that it is an open ground how do I fix it?
Old Nov 17, 2000 | 07:15 AM
Remove the bulbs from the sockets & check the socket ground contacts for continuity to chassis ground with an ohm meter or a test light.
Tim
RABMAN
Interior Parts Wanted
Sep 18, 2015 09:02 PM
Jk_Under
Sep 2, 2015 10:59 PM
bklucas12
Jan 11, 2002 06:44 AM
super83Z
Jun 2, 2001 10:44 AM
Jimmy91RS
Sep 28, 2000 02:16 PM
