That damn tpi!!!
Old Nov 5, 2000 | 07:30 PM
Tonyrodz's Avatar
Transmission: auto
That damn tpi!!!
Have a question--My injectors aren't firing so I bought a test light for them--not getting any spark from cranking--also not getting any power to ecm(also no check engine light)--so I run a hot lead to ecm--still doesn't start--run a hot lead to injectors in ecm(forgot pin #'s)so now it's hot--tried cranking w/test light-still nothing--now what?? I'm gonna wind up parting this car out!! Any ideas??
Also one of the hot wires touched the ecm and sparked--think this fried the ecm??
C'mon guys I have faith in you!!
Old Nov 11, 2000 | 12:55 AM
turbo497's Avatar
what is you fuel pressure you should be around 30lbs-40lbs
Old Nov 11, 2000 | 10:17 PM
Tonyrodz's Avatar
Transmission: auto
I don't have a pressure gauge, but the fuel pump is hot wired directly to the ignition.
It's definitely getting fuel pressure and spark. Just found that the ecm isn't getting any power to it--shows hot on the fuse panel(ecm fuse is hot)Also the inj. aren't getting any juice either--not pulsing on.
Have any ideas?
Thanks for any and all help!!
Old Nov 14, 2000 | 07:56 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
There may be another another 20 ampere ECM / fuel pump fuse in line near the battery.
Tim
Old Nov 14, 2000 | 01:51 PM
Tonyrodz's Avatar
Transmission: auto
Fuel pump still works. Guy has it hotwired to the ignition. I'll check tho. This car turned into a real nightmare!!
Old Nov 17, 2000 | 08:58 AM
TexasLT1's Avatar
Car: '92 RS
you might want to check out the VATS system, I had the same problem when I swapped engines, I was getting, fuel and spark, only difference was mine would crank, start, run for 1 second, and shut down. Only reason it did that was I bypassed some part of the system with the new computer. But I would check that out, you might find your problem
Cornholio7979
Sep 20, 2018 02:31 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
aaron7
Aug 26, 2015 09:45 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
