Car won't start, buzzing relay
Old Nov 17, 2000 | 02:32 PM
Dagon7's Avatar
Someone tried to steal my car, and it the process screwed it up so now I have to start the car with a screw driver (pulling metal linkage in steering column towards driver).
Anyways, the car has worked fine besides that problem for a couple of weeks. I haven't had the money to get the column repaired.
But, today I tried to start it and it won't start. I've noticed that the relay that has some big gauge yellow,green, green/white wires going into it makes a funny sound. What is that relay, what does it do? Is that my problem?
89 IROC-Z
350tpi A4 2.77's
!MAF,!Airbox,170 Thermo, Fan switch, Poly trans mount,Moog Idler Arm
Ported Plenum, AFPR,
Ford 24lb injectors
****ing Code 33
Old Nov 18, 2000 | 08:48 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Your '89 should have a VATS (vehicle anti theft system) - your key would have a resistor mounted in it, if so. The relay you are describing sounds like the VATS starter enable relay. I'm curious how you were able to get the car to start at all without the proper resistor input to the VATS?
Tim
Old Nov 18, 2000 | 02:33 PM
Dagon7's Avatar
It has an aftermarket alarm that's been disabled. I assume they disabled VATS to do this. What's got me, is why then is the starter relay(VATS) all messed up?
89 IROC-Z
350tpi A4 2.77's
Ford 24lb injectors
Old Nov 18, 2000 | 02:35 PM
Dagon7's Avatar
Another thing is, that the key is stuck in the ignition.
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
