When i put my bright lights on then all of my lights go out.. WHY?
Old Nov 19, 2000 | 10:31 AM
Artic White Z's Avatar
Last night when i went to put my bright lights on it didnt seem to right. it seemed like i had to hold the switch back longer to get them to work. i put them back on low and then on high again after several tries and then all of the lights started flickering on and off. whats wrong? is the dimm/bright switch broken? How do i fix it?
Thanks for the help,
Alan
Old Nov 20, 2000 | 04:45 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Sounds like either the switch is bad. Check the grounds on the head lights. Do all the lights go out or just the headlights?
William
Old Nov 21, 2000 | 02:07 AM
Chris Luongo's Avatar
Also, there's a built-in circuit breaker inside the headlight switch. If you've added extra headlights, or there's some other problem in the circuit, the breaker will turn on and off repeatedly.
Old Nov 21, 2000 | 01:05 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If it is the hi/low beam switch causing the problem, the switch is located near the ignition switch, on the steering column.
Tim
92camaroJoe
Jul 29, 2023 07:57 PM
Jae992
Aug 27, 2015 09:07 AM
Fronzizzle
Aug 17, 2015 02:52 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Omega
Aug 10, 2015 12:46 PM
