TPI swap wiring question
Old Nov 20, 2000 | 03:06 PM
MrDano's Avatar
Car: 1987 Monte Carlo LS
Engine: 357 TPI, LT4 hotcam
Hi, I am swapping a '88 IROC L98 TPI into my Monte Carlo and have a question about the TPI wiring harness. I need to know what the Light brown (maybe Tan) wire (PIN D of C207) is used for. I have checked with a meter and it goes to the middle wire on the alternator. I only have an 86 Firebird manual and it does not have the same alternator. (v-Belt not serp)
Thanks,
Dan
Old Nov 22, 2000 | 06:56 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Here's the '87 configuration - it may be the same:
Outside red wire (terminal S) - to large terminal on starter; battery power.
Middle brown wire (terminal F or I) - to 20 ampere FP FAN fuse that is hot in run only.
Outside brown wire (terminal L) - to volts indicator idiot light. (The other side of the idiot light connects to the 10 ampere gauges fuse, which is hot in run and start.
Tim
Old Nov 22, 2000 | 09:49 AM
MrDano's Avatar
Thanks Tim. That is exactly what I needed to know. I am hoping to finish the wiring and have a running car by the end of the weekend now.
midge54
Sep 2, 2020 07:13 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
