Tach and shift light question
Old Nov 18, 2000 | 10:43 PM
84FTA's Avatar
I was just wondering if anyone knew if the stock tach works on amperage or on voltage? I want to hook up a stock shift light without the ECM connected. I can do the electronics work myself, also, it won't tell me to shift too early like real stock ones .
Thanks for any help.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 WS6 Trans Am T-top car
4-bolt main 350, headers, Holley 650, T-5 and 3.23's.
Daily driver and restoration
Old Nov 19, 2000 | 02:29 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I believe it's neither, it's pulse modulated.
1984 Silver Z28, 383 cid 4 bolt, ARP Fasteners, 2 1/2" Cowl Induction Hood, 600 cfm Performer Carburetor, Torker II Intake, Performer RPM Heads, XE268H Cam, Magnum Roller Tip Rockers, MSD6AL Ignition, Blaster2 Coil, Recurved HEI Distributor, 700R4, TransGo SK, 2.73:1 Limited Slip Dana 44, Terminator Headers, Custom 3" TIG Welded Stainless Exhaust, Flo-Pro Twister Muffler, 4 Wheel Disc Brakes, Oil Cooler
Old Nov 19, 2000 | 08:23 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
A tach uses a frequency to voltage converter to drive an analog meter. It is possible to tap off of the output of the F to V circuit & drive a voltage comparator circuit that would operate a light.
Tim
Old Nov 23, 2000 | 08:19 PM
84FTA's Avatar
How about if I came off the coil feed and ran a low pass filter to operate the light?
Old Nov 24, 2000 | 08:55 AM
A simple LPF would not do the trick. You could build a F to V converter with an LM122 (precision timer), or an LM2907 (frequency to voltage converter), or a simple system, with discrete transistors. You could also buy an MSD RPM activated switch module (< $100, from Summit) to control a shift light as a function of RPM.
Tim
redmaroz
Aug 16, 2015 11:40 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
stalkier
Aug 7, 2015 04:49 AM
