windows won't work at all?????
Old Nov 18, 2000 | 11:45 PM
camaro 22's Avatar
i just bought a 91 rs convertible from auction, and neither window will work at all. what could be the problem with them? i was told by the guy that he tried them once, and they did work at first, then just failed.
Old Nov 19, 2000 | 08:14 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The window motors are powered through the 30 ampere WDO circuit breaker, located in the fuse panel, under the dash.
Tim
Old Nov 19, 2000 | 10:33 AM
Artic White Z's Avatar
yea check the fuse box to make sure there getting power.
Old Nov 23, 2000 | 10:00 PM
Chris Luongo's Avatar
If you suspect that the circuit breaker has gone bad, you can just put a fuse in there temporarily.
Old Nov 24, 2000 | 06:26 PM
camaro 22's Avatar
i compared my 91 with the windows not working to my 89 which do, and noticed there are different wires on the 91. looks like the previous owner had his security system hooked up to the window switches some how and for what, i don't know, but when he ripped out his system, no power is getting to them. how could i get them to work again?
Old Nov 24, 2000 | 11:29 PM
Yes, the car could have been wired so that the windows would roll up when the alarm is armed...or you can even put the windows down by remote.
They probably would have cut some of the wires in the center console, and wired in some relays or a special window control module. Just take the stuff out and hook the wires back up the way your other car is.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
