Power doorlocks Reverse Polarity????
Old Jun 2, 2002 | 07:41 PM
snoozeyaloose85's Avatar
I got this bulldog keyless entry for my 85 TA and they say in the instructions the door locks are positive so I hooked them up and they dont work. So I got some relays and hooked them up reverse polarity and they work is this right??????
Old Jun 2, 2002 | 08:15 PM
2vmodular's Avatar
door lock actuators themselves are a reverse polarity setup. applying power with postive on one terminal, negative on the other, locks the door. reversing which wire has positive and which has negative will unlock the doors instead of lock them.
most alarm installers would not tie directly to the actuators though. instead would tap the wires that run from the door lock switches to the door lock relay assembly. such a setup would be known as a "postive trigger" door lock system.
schematics and some other door lock related info are avaliable at http://www.geocities.com/modularmotor/thirdgen
deracer
Apr 11, 2016 12:04 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Rakim_RS25TH
Aug 27, 2015 05:04 PM
sailtexas186548
Aug 24, 2015 10:11 PM
hokis
Aug 9, 2015 03:57 PM
