Speedometer quit working after plug change, getting a code 12
Old May 28, 2002 | 01:58 PM
StangKiller's Avatar
I changed my plugs yesterday, then went for a drive today and noticed the speedometer was not working, I figured I pulled a wire loose somewhere, so I checked all the wires and nothing is loose, checked the codes and I just get the 12 flash over and over, flash pause flash flash long pause flash pause flash flash. Is that normal for no codes? I know it's supposed to flash 12 3 times and then give the codes but all I get is 12, other than the speedo everything works and it drives good, thanks for any help.
Old Jun 2, 2002 | 05:30 PM
12 Sec GTA's Avatar
Car: 98 Camaro SS
Transmission: M6
if it only flashes 12, then there are no codes being thrown.
Old Jun 2, 2002 | 08:46 PM
Jza's Avatar
Jza
That probably means something between the ECM and the speedometer is messed up. If something between the ECM and the signal generator at the transmission were messed up, you'd get a code 24.
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
jharrison5
Aug 19, 2015 05:53 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
