Foglights don't work anymore
Old May 30, 2002 | 09:25 PM
PimpWillis's Avatar
Car: 88 Iroc
Engine: LB9
Transmission: WC T-5
Sup guys..the foglights in my iroc just started acting up. The one foglight stopped workin and i got out of the car and tapped on it and it went back on....The next night i went to turn them on and niether of them worked..I checked the fuses and i tapped on the fog themselves whatelse could it be?
Old May 30, 2002 | 09:45 PM
mudaholic's Avatar
loose connection at the light perhaps?
Old May 31, 2002 | 10:29 AM
Flamingo's Avatar
Car: 89 GTA
Engine: 5.7 TPI
I realize this wont explain the tapping working, but you do realize that your lights have to be on dim or parking lights on for the fog lights to work? With that in mind, as mud said check for loose connection at light. Are you getting power there? The fog lights are run off of a relay in the front of the engine bay on the drivers side. Are you getting power there? Are you getting power at the switch?
As a side note, I have taken that relay out so I can run the fogs whenever I want to, and also because it is wired up in such a way (stock) that it screwed up my headlights when I modded them. That relay is there so that the fogs will only work in the conditions stated above rather than actually power the fogs. There are wiring diagrams in the tech section, check them out.
Old Jun 2, 2002 | 09:20 PM
Desert86Roc's Avatar
Foglight relays go bad often. It is probably your relay. on my IROC it is located next to the horns on the front/inside of the driver side fender.
1992rs/ss
Jan 31, 2025 05:10 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
TheExaminer
Aug 26, 2015 04:59 PM
dhonda200
Aug 11, 2015 11:50 PM
guy76767
Aug 6, 2015 05:58 PM
