Uq7 Subwoofer System
Old Jun 3, 2002 | 10:19 AM
tommydodso's Avatar
I NEED SOME ONE WITH A UQ7 SUBWOOFER SYSTEM IN THEIR CAR TO HELP ME OUT. I HAVE THE AMP AND THE SWITH THE WIRING BUT MY PROBLEM IS THAT I DO NOT KNOW WHAT WIRES GO WHERE FROM THE AMP TO THE SPEAKERS AND WHAT WIRE GO TO THE AMP FROM THE STEREO. THIS IS THE SLIDE SWITCH ON THE DASH BOARD OF THE TA'S/GTA'S.
ALSO DOES ANYBODYS WORK WITH AN AFTERMARKET RADIO?
THANKS TOMMY
Old Jun 4, 2002 | 11:58 AM
2vmodular's Avatar
are only two wires going to the "subwoofers" in the back. both "subwoofers" run off of one channel and are bridged mono.
amp can be used with an aftermarket stereo, but you'll need to use a relay. amplifier is powered by the antenna turn on which is acceptable with the stock radio. but most aftermarket radios will not be able to output a sufficent amount of power on the power antenna lead for the amp.
Old Jun 4, 2002 | 01:06 PM
tommydodso's Avatar
UQ7
IS THERE ANY WAY YOU CAN TELL ME WHAT WIRES WENT IN TO THE AMP FROM THE RADIO AND WHAT ONES WENT TO THE SPEAKERS. THERE ARE A BUNCH OF WIRES ON THE WIRING HARNESS. I CAN FIGURE THEM OUT.
THANKS TOMMY
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
Night rider327
Sep 25, 2015 04:47 AM
84 TA NV
Sep 6, 2015 08:02 PM
