Need Info on dule coolign fan wiring, have a charging problem
Old Nov 29, 2000 | 07:29 PM
Stell1579's Avatar
i know, bad speller....
i have the 2 fans one switched by the computer, the other the ac, and sensor on th eblock howmany amps does each fan pull? i have a big drain on my charging system but only when the fans are on. i havenot tested to see howmany amps each are pulling yet but will prolly tomorro. howmany amps is normal range? if i am pulling to mutch is could that have killed a batery to the point where it would start the car no problem, but blewup on a batery tester, and killed 4 altinators in the process?
thanks
-Stell
1988 IROC 305TPI MINT!!
Mods= Accell SuperCoil, MSD 6A, Ported Plenum, No MAF Screans , K & N, 160 Thermostat+ Temp Switch, Relocated MAT, Cold Air
Old Dec 1, 2000 | 05:12 PM
Stell1579's Avatar
Anyone Know this?
Old Dec 1, 2000 | 06:28 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Each fan motor draws around 8 amperes at nominal system voltage. Also, someone had measured the inrush transient current peak to be approximately 21 amperes, when the ran is spinning up.
Tim
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
