switch rating???
Old Dec 7, 2000 | 03:06 PM
Josh 91RS's Avatar
switch rating???
Going to install a brake light switch to cut off the brake lights with a switch. Its a normally open, momentary, pushbutton switch. Weve already had the conversation about how to do this, however im just wondering if a switch rated at 6A @ 125vac will be sufficient. This is the biggest momentary normally open i could find. What do you guys think??
Old Dec 8, 2000 | 01:40 AM
Omar's Avatar
The rating should be enough. If you have a normally open switch, you are gonna have to use a relay with it. Breaking off the ground wire would be the easiest and safest way.
1989 IROC-Z 5.7L
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Randomtask2
Sep 10, 2015 08:37 AM
luvofjah
Sep 3, 2015 07:08 PM
