valet switch install?
Old Dec 5, 2000 | 07:56 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I want to install a "valet switch" so when others drive my car they get part instead of full throttle. How do I do it?
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup, Dual IROC Fans.
http://www.sethirdgen.org/octride.htm
Old Dec 5, 2000 | 08:30 PM
JPrevost's Avatar
Car: 91 Red Sled
We have a mechanical cable for the throttle so scratch anything cheap and easy. Only other thing is to either get that JET 6 stages system or to buy a rev limiter which are usually built into Digital ignitions like MSD.
, Jon (91 RS too many mods to list)
Old Dec 5, 2000 | 08:52 PM
Engine: 4.0L
I don't want to pop the hood every time I want to engage the valet switch like you would with the throttle cable. That is if the cable did the valet function.
86 Camaro Sport
Old Dec 5, 2000 | 10:16 PM
Chris Luongo's Avatar
Yeah, couldn't you get an MSD and get the correct chip to limit the RPM to, say, 2800 or so?
Old Dec 6, 2000 | 05:26 AM
Engine: 4.0L
I have a built TPI 383, it has monster torque especially from idle to 2800 rmp so a rev limiter will not do what I'm asking. I want to cut the torque/horsepower down when I let other un-experianced drivers drive.
86 Camaro Sport
Old Dec 10, 2000 | 09:41 AM
blowen90ta's Avatar
so ya got lots of torque,just use a lesser rpm pill mine is set to 2200 rpm and uses a msd 2 step one for the normel 6000 and the other 2200 activated by grounding a wire to the 2 step.i have a key in my center console to activate the VALET MODE and it works great no need to worry when i take the car in for service that some punk is out beating my ride.and if the girlfrend is driving the car is still very driveable.
later
Caspar
Jun 19, 2016 11:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
toronto formula
Nov 10, 2015 06:17 AM
dcbsracing007
Aug 18, 2015 07:24 AM
86IROC112
Aug 17, 2015 02:00 PM
