91 RS WILL NOT START!
Old Dec 10, 2000 | 03:34 PM
Ricky Bettinger's Avatar
1991 RS VIN "E" has not been driven in two month. Battery is totally dead but replaced it. Engine turns over good and fast but there is no fuel to injectors and can not hear fuel pump.Can someone give me directions or instructions.
Old Dec 10, 2000 | 08:01 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Hmmm, how about: replace fuel pump?
It could be the fuel pump relay, or oil pressure switch, but the engine will run with one or the other, and I highly doubt they both failed at the same time. I would check for 12V at the pump either during initial 2 sec. prime or while cranking, and if you have it, put a pump in it.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 11, 2000 | 12:00 AM
Chris Luongo's Avatar
I belive there's a fuel pump fuse....couldn't hurt to check it.
Old Dec 11, 2000 | 06:20 AM
GMTech & Chris thanks for the info. The shop wiring diag. tells me that a inline fuse no.3 is on the right of the batt. But the only fuses that are thier is 14 & 18. I have replaced the relay, checked the injector fuses. I have a new GM fuel pump hand. Where do you check the fuel pump voltage? Can it be checked under the hood? Thanks guys
Update: 12-14-2000
Fuel pump is working.
I have fire to the plugs.
Injector fuses are good.
fuel pres. is good.
VATS is online key code OK.
All wiring is in place and OK.
Checked all grounds OK.
The only thing left is the ECM. What do you guys think did I miss something?
[This message has been edited by Ricky Bettinger (edited December 14, 2000).]
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
