Ammeter installation
Old Dec 11, 2000 | 05:19 PM
Bort62's Avatar
Ive got a summit ammeter, and It says to Install it Inline with the Horn Relay, Or junction terminal. Problem is, I cant Find the Damn Horn Relay... Where is it at?
If its in a Inconveint place, is there any Other method to installing htis Ammeter that would work ?
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 13, 2000 | 07:28 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
An ammeter is generally placed in line between the battery and the loads & alternator (excluding the starter), to give an indication of whether current is leaving or entering the battery. This is a bit difficult to do on most vehicles, as power is taken from the large lug on the starter, and from the battery cable, near the battery. These circuits would have to be combined with the alternator charge wire & connected to one terminal of the alternator, while the other terminal of the alternator would have to be connected to the battery. Also, heavy 8 or 10 gauge wire would have to be routed into the passenger compartment, which is quite combersome. An easier solution would be to use a volt meter to give an indication of the status of the charging system.
Tim
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
