Does the fuel pump??????
Old Dec 17, 2000 | 06:42 PM
Palz's Avatar
I'm trying to do a fuel flow test on my fuel pump on a 92 305 TBI because it is acting like it is failing. When I went to do the test the the fuel pump kicks on for a few seconds like normal but I did'nt get any flow. I have to crank it to get it to flow and then it flows fine. Shouldn't the pump continue to flow until charged when in the ignition is turned on but not actually cranked?????????
Old Dec 17, 2000 | 06:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
When you first turn the key "on" the fuel pump will come on for 2 seconds. If you lost a lot of fuel when you disconnected the line, that 2 second prime probably just filled up the empty lines. Once the lines are full (don't let them drain) it should flow a little next time you cycle the key. The 2 second prime isn't to flow fuel, its just to pressurize the system.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
