Timing
Old Jun 6, 2002 | 09:17 PM
88-convertable's Avatar
Timing
I have a 88 305 tpi with a hypertech chip and 160 stat.What is the highest base timing that can be run??
Old Jun 6, 2002 | 09:21 PM
383 rocket bird's Avatar
Every engine is different and ideally you should advance it using a scan tool until the point right before you start to get any readings from your knock sensor. Those LB9's are detination prone as it is so without a scan tool I would not go very far.
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
