Electronic Speedo Question
Old Dec 21, 2000 | 04:12 PM
90FFBird's Avatar
Can an electric driven speedo be wired to work without the computer? I have done away with my '90 computer and it appears that it controlled the speedometer. I still have the two output wires from the trans but need to know where they need to feed to in order to get the speedometer to have a signal. Thanks, Rob.
Old Dec 21, 2000 | 07:05 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Check this out... www.angelfire.com/mt/psh/speedo.htm
Pete
Pete's Place
HiOutput Virtual Racing Team
Old Dec 22, 2000 | 07:37 AM
90FFBird's Avatar
That looks like it should work, only problem is I can't find the speed buffer box. I have a black box "piggybacked" to the ECM, but it looks nothing like that. It is a balck shell containing a printed circuit board that is loose (just not attatched to the box) and has one plug into it. The plug slides directly onto the board and makes contact on the printed circuits. I was thinking this was cruise controll module but I could easily be wrong. This car originally came with the electronic dash, I just need to get it working again. The computer was replaced with an '89 model to run a MAF TPI system. Thanks for the help, Rob.
Old Dec 23, 2000 | 11:48 AM
90FFBird's Avatar
Old Dec 26, 2000 | 08:55 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I have what you need and will be willing to sell (I converted my '87 carb to '92 TPI, so I don't need it any more)
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Eric2ndGen
Nov 5, 2015 01:51 PM
stickychinsac
Aug 31, 2015 06:06 AM
IROCZDAVE (88-L98)
Aug 24, 2015 06:54 AM
redmaroz
Aug 16, 2015 11:40 PM
