O2 Sensor, Need HELP!
Old Dec 8, 2000 | 01:19 PM
84TransAm's Avatar
Will a disconnected O2 sensor cause a change in the ignition timing sequence? Just read that it would (could?) in the modification section. I disconnected it to change my valve cover gasket, can't reconnect it and now my car has a "miss" in the idle. So I'm afraid to drive it before i get this "miss" figured out!!!!
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
Old Dec 9, 2000 | 09:32 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
I'm not sure what the ECM algorithm does when it detects a faulty O2 sensor - it's possible that the spark curve is modified. If the M/C solenoid on the carb is not "clicking" while the engine isrunning, chances are that the mixture is very rich, which could make the engine miss. The oxygen sensor will need to be reconnected.
Tim
Old Dec 10, 2000 | 12:35 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
buy a new one....$20.
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 5/8 shorties, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo on the way)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Dec 29, 2000 | 09:12 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When the O2 sensor in the 83 Z goes bad we get a check engine light, but the car runs fine. Whe the O2 sensor in the 81Z goes out it pings like crazy when you hit the gas hard. O2 sensors are cheap, except at the dealer.
Z's r Best
Old Dec 30, 2000 | 08:05 PM
84TransAm's Avatar
I replaced the Sensor, car runs great and it did ping at startup and a bit after warmup (i mean miss) but it is all good now, and it's great to have this thing back on the road after a 1 month vacation. (for the car, ran out of $$$). But i discovered it is a LG4, non-HO engine so now i have to make it better than those HO punks
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock emissions restricted slow 150 hp(chilton rating) 240 torquer that needs RELEASE!!!!
P.S. Daily Driver
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
