trouble codes
Old Jan 4, 2001 | 10:19 PM
cjstylin's Avatar
trouble codes
i have a '87 camaro. i hooked a scanner up to it and trouble codes 41 and 45 come up. the scanner doesn't tell me what they mean. what do they mean?
Old Jan 4, 2001 | 11:05 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
41= Cylinder select error.if the calibration chip has been recently replaced, this code has been set because the programming is incorrect for the car. if it has not been replaced recently, then check for signs of corrosion. if there is no corrosion, replace the calibration chip.
45=connect a digital voltmeter to the ecm terminal for the purple oxygen sensor input wire. run the warm engine 1200 rpm for two - three minutes and note the voltmeter. if the voltmeter is cycling throughout the entire oxygen sensor output range, the problem is intermittent and no repair is indicated at this time. if not, disconnect the oxygen sensor and ground the purple wire. if the voltmeter reads greater than .35 volts, inspect the purple wire for a short to voltage. if the purple wire is ok, check the following: fuel pressure, leaking injector, induction source to the purple wire, saturated evaporative canister or defective purge valve, maf and tps. if all of the above test ok, then replace the ecm.
Does that answer your question?
You might have a bad ecm.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
Lmancha96
Sep 25, 2015 08:11 PM
