I've got a WIERD tach problem!
Old Jun 9, 2002 | 08:29 PM
RS'er's Avatar
It says I idle at like 2750 and cruise at 5 or 6k.....
It is obviously working and moves just fine,but the reading is really 2 or 3x's what it should be. Is there a simple fix to this?
How do I fix it?
Old Jun 9, 2002 | 09:16 PM
Morley's Avatar
I'm working on a fix for this, I have the same problem as do a few others, though not as drastic as yours is. I'll post back with the results when the parts I ordered get here and get put in the tach.
~M~
Old Jun 16, 2002 | 06:49 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
tach
yea mine did the same thing it read double soooooo i took off the needle and put in an auto meter works great lol sorry cant tell u how to fix yours just what i did to mine
Old Jun 16, 2002 | 07:35 PM
IROCmonkey's Avatar
Car: 85 IROC
Engine: LB9
I had the same problem with my tach when I first got the car...I replaced it with a guage pack I ripped off an 89, I think it was an RS...hehe I wanted the speedo...but snagged the tach too. Mine still reads off by probably like 10-15% so I would love to hear another solution too.
Old Jul 1, 2002 | 01:02 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I had the same problem after I replaced my coil. I but the new one in the same way the old one came out, but it was running double. I then went to a more reputable parts dealer, and got a new coil from them, and after talking to them, I went through and double checked my ground for the coil. This was the problem. Neither the original or the first one that I bought had the proper grounding strap, I put the grounding strap (more like a metal strip) onto the coil, and it went to exactly what it was supposed to be.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
