Missing ECM pickup wire for adjusting timing!
Old Jun 9, 2002 | 08:31 PM
RS'er's Avatar
I'm missing the "tan wire with a black stripe" that you disconnect to properly adjust your base timing....probably just me,but I've been looking and looking...where the hell is it!?
Old Jun 9, 2002 | 09:02 PM
88-convertable's Avatar
mine is located on the passengers side just above the blower motor.
Old Jun 10, 2002 | 06:30 AM
1986redbird's Avatar
I have a '86 bird and I havent found the "wire" yet either, If you cannot find it you can still set your timing by disconnecting the 4 wire connector coming out of the dist., this connector usually drops down behind the engine somewhere near the bellhousing just under the dist., thats how I set my timing and have had no problems doing it.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
marcusaw
Aug 10, 2015 08:13 AM
Exxon Limited
Aug 9, 2015 08:13 PM
