My headlights are killing my car
When I turn the lights off, the car will shudder, then die. I have the problem with blowing the dash\taillight and headlight fuses periodically, but this new problem has just recently cropped up. Any ideas on what could be causing this?
86 Trans Am 305
Bone Stock (unless touch-up paint is considered a modification)
86 Trans Am 305
Alternator
86 Trans Am 305 TPI,Bored 30 over,Blower Cam,Fordged Racing Pistons,High Volume Oil Pump,3" Flowmaster Exhaust,Hypetech Coil,Acell 300+ Race Wires,Bosch Platinum +4 Plugs.Best Et was 12.5 with a Paxton.
That thought had crossed my mind. A guy at work told me to disconnect the battery while the car is running, and if it dies, there is definately a problem with the alternator. Think I'll give that a shot and see what happens.
86 Trans Am 305
86 Trans Am 305
Disconnecting the battery like that is not a good idea. If there is a problem with the voltage regulation, disconnecting the battery's charging load could let the system voltage get way to high, and possibly fry the electronics. A better way is to take the alternator off and have it tested at your local parts store. Alot less trouble and cost then replacing fried ecm or radio etc.
82 T/A 305/TH350; soon to be 350/T-5
Iroc8t8
May 4, 2026 08:09 PM
Ghettobird52
Jul 5, 2024 11:18 PM
db057
Aug 11, 2015 10:11 PM
