thermostat gauge not working
Old Jan 5, 2001 | 10:03 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Need some help, friends 85 Z28 thermostat is not working. The needle is stuck in high position in the morning when first turning the car over. Engine is cold and yet the temp reading is above 220 degrees. He replaced coolant thermostat and went as far as replacing the temp gauge. Still reading high from a cold start. Member has a code 32 and a 43. Any help would be appreciated.
Old Jan 6, 2001 | 04:50 PM
billyde's Avatar
You replaced the coolant sensor in the intake manifold right? not the one down in the block.
Old Jan 8, 2001 | 02:13 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The coolant thermostat does not control the temperature gauge - the temperature sender on the driver's side cylinder head, between cyls 1 & 3 control the gauge. Make sure the wire is connected - if it is, then replace the temperature sender.
Tim
Ghettobird52
Jul 5, 2024 11:18 PM
Jeremys87
Jul 14, 2022 09:08 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
justin57
Aug 20, 2015 07:05 PM
