Headlight servo wiring help needed
Old Jan 9, 2001 | 10:59 PM
Don Christensen's Avatar
Car: 1989 Formula - Red
Transmission: 700 R4
Axle/Gears: 3.73 Posi
I'm new, but this is a great board.
My wife has an 89 Formula and my daughter has a 90. Her headlight servos are shot. They are the type with two wires.
I've acquired a set of earlier servos with three wires going onto them and with a relay on it. Does anyone know how I can adapt them to the 90 Bird.
So far I've figured that the red/white wire going into the relay is always hot. The black wire going into the relay is ground. I believe that the pink wire going into the relay is the signal wire to flip the lights up. My question is how do I close them? I suspect that the white wire going into the servo does that, but if that is the case then where do I run it to?
Many thanks in advance!!!
IROCZ1989
Jan 24, 2016 03:55 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
