timing for the 86 305 tpi
Old Jun 12, 2002 | 10:49 AM
SMOKEN's Avatar
guys i need some help here lastyear i ran a 15.6 at 92 mph then i had a coolent leak i got the hose changed then i find out that my mechanic played around with the timing he said that it was 4 degrees retard . the thing is now the car pings bad and i run in the 16 's the car only has 38 000 kilometeres there is a hypertech chip in there. can someone please tell me if the timing can be the problem with my car thanks
Old Jun 12, 2002 | 04:28 PM
Wolfpack's Avatar
Car: 86 Iroc
The best thing to do would to put a timing light on it and check it yourself.....i think there isa tech article on the board somewhere...plus you can find out how to do it from a shop manual....your machanic prob didn't unplug the ESC(is that right?) when he reset your timing and that would throw the whole thing off if he didn't....Good luck
Old Jun 13, 2002 | 09:23 AM
mtccl's Avatar
Unplug the ESC wire (brown/black) near the blower motor passenger side of the engine compartment. Set timing between 6 and 12* BTDC. Mine runs best around 9* on premium pump gas with lite intake mods. Turn the distributor with the car running and listen for the best setting. Don't be afraid to play with it some. Have someone else turn off the ignition while you are holding the distributor in the sweet spot and immediately tighten the distributor hold down bolt. Restart, check timing again. Reconnect ESC wire. Disconnect battery to clear the code and enjoy! G ood Luck!!
Old Jun 15, 2002 | 12:39 PM
SMOKEN's Avatar
thanks for the info this week i will try this i hope i can at least run 15.2 ???
BlueIroc-Z
Jun 9, 2019 03:22 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
