help me track down a short
Old Jun 12, 2002 | 11:19 PM
92superram's Avatar
Ok guys, I have a short somewhere. The interior lights, power locks, and cig lighter don't work. I put a new fuse in, and it poped. Has this happened to any of you? Is there any place on that circuit that commonly shorts? I will finally have time to try to track down the short tomorrow, so any help would be great.
Old Jun 13, 2002 | 12:05 AM
2vmodular's Avatar
cigarette lighter assembly is often troublesome
aftermarket radio installs sometimes cause problems with this circuit
domelight wires have been known to short against the metal roof
Old Jun 13, 2002 | 06:04 AM
1986redbird's Avatar
check in the cigarete lighter, I have known pennys to fall in there and that will cause a dead short.
Old Jun 13, 2002 | 08:51 AM
92superram's Avatar
I hope it's not on the roof, that would be a huge pain in the ****.
Old Jun 13, 2002 | 11:16 AM
irocz8292's Avatar
If I was you I'd first check the A-pillar along the driver window. that is where the wires for the dome run up then across the windshield, then back to the light. They sometimes get kined in that area and by the dash. Have u ever had it apart? maybe you crushed a wire while putting it back together.
Old Jun 19, 2002 | 03:06 PM
esmartuek's Avatar
Car: 87 Camaro LT
Engine: 305 4BBL
Transmission: TH700R4
I actually had a very similar problem just this last week.
I probably went through 10 fuses finding the problem.... bent prong in my cig lighter... was spittin out sparks when I replaced the fuses.
I also ripped out my rear defroster switch cause it was making alot of noise.
check those...
-ET
FormulasOnly
Jul 23, 2018 08:47 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Oct 5, 2015 06:23 PM
evilstuie
Sep 24, 2015 02:31 AM
ctoledo0834
Sep 18, 2015 04:16 PM
