Installing a Digital Dash!
Old Jan 20, 2001 | 12:51 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I recently found a Trans Am for sale and I will be acquiring it soon! It's an '87 or '88 I belive! Anyhow, I plan on removing the Transmission and using it in my car....selling the TPI out of it....and junking the 305! I'll probably hang on to the wheels as well but as for the body, I'm not keeping it! Well, this car has a digital dash.....one of the very few that had it! I would like to swap the digital dash out of this car and into my '86 Trans Am! I know the computer chips in the '86-'88 or '89 are the exact same chips so does this mean I can just take the dash and swap it into mine w/out swapping the computer?? What all would I need to swap? Wiring harness maybe also?? If anybody has any insight or suggestions about this topic please let me know!
1986 Trans AM
305 TPI
Completely Stock
Soon to upgrade to a 327 TPI with pocket ported 64CC heads, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Jan 20, 2001 | 07:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You will need the wiring harness from inside the car. And if it has the "information center", then you will need the "lamp monitor" module down by the steering column also.
P.S. want a spare dash?
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 20, 2001 | 10:21 AM
turbo497's Avatar
does the car have electronic climate control
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Sanjay
Aug 12, 2015 03:41 PM
beachrodder
Aug 7, 2015 04:27 PM
