Help!!Back up lights won't work
Old Jan 19, 2001 | 04:43 PM
86-Z's Avatar
i have an 86-z28 5-speed and about a week ago the reverse lights stopped working.I checked the fuses and they were all fine and replaced both bulbs.I don't know where else to look or what else to do help!!!
Old Jan 21, 2001 | 12:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The reverse light switch is mounted to the transmission & has a 2 wire plug connected to it - remove the plug & short the two terminals together in the harness at the plug. Turn the ignition on - if the lights illuminate, replace the switch mounted to the transmission. If they do not illuminate, the problem is elsewhere in the electrical system.
Tim
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
justin57
Aug 20, 2015 07:05 PM
Omega
Aug 10, 2015 12:46 PM
