Shaved Door Handles w/ Remote Door Poppers
Old Jan 19, 2001 | 01:33 AM
Mike Harvey's Avatar
How do you do this? I know that the handles need to be taken off & the key entry hole & then filled w/ bondo but how can it be done to a Firebird like mine that does not have Power Locks? Thanx & sure hope someone there has done it so they can guide me in the right direction when I decide to do this. Thanx
- Mike Harvey -
1986 Firebird S/E
Old Jan 19, 2001 | 10:35 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
You don't need power locks to shave your handles.The solenoid connects to the lever that pulls the mechanism to release the latch.If you take your door panel off and follow the rod that is connected to your door handle,you will see the lever that it is connected to.It should have another eyelet where you can connect the solenoid to to pull that same lever down to unlatch the door. Mounting the solenoid straight up and down inside the bottom corner of the door under the latch is probably the best place for our doors.I've done probably about a dozen shaved kits for f-bods,and a few more for other cars,so if you have any more questions,just e-mail me.
P.S- It's better to have sheetmetal welded in place of the door handles and lock cylinders instead of bondo.
'91 RS 5.0 TBI
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
Eibach sportline springs
ASCD SS hood
Flowmaster cat-back
TBI mods
383 implantation soon to come.
Old Jan 24, 2001 | 03:41 PM
JPrevost's Avatar
Car: 91 Red Sled
What kind of solinoid do we need? How much effort? Also why not use sheet metal for both the locking mechanism and handle then bondo? I know the poppers are only $5 each and I have a remote with 4 extra channels and I'd like to just get the solinoid so where and which? I have the relays etc.
, Jon (91 RS too many mods to list), getting new engine in summer
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Oct 9, 2015 10:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
kkirch15
Sep 30, 2015 04:44 PM
