I think this mechanic is trying to rip......
Old Feb 1, 2001 | 05:23 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
I need to know if mass air flow TPI cars have a map sensor also??? I think my friends mechanic is trying to rip me off!!!!!
1991 Firebird
350 L98 (was a 305 TBI)
T-5 transmission
Edelbrock TES and cat back
Accel manifold
NOS
subframes
jegster torque arm
MSD Digital 6
AFPR
Lakewood lcas
hurst linelock
SLP cam
relocated battery
cold air
Hypertech chip
centerforce clutch
poly bushings and mounts
etc..
14.1 @ 99mph with just headers and catback
with NOS and other mods???? twelves??
Old Feb 1, 2001 | 06:19 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Actually in some cases this IS true! I never saw it on V8 cars but some '88 and '89 2.8 MPI cars had both. I think they had a recall or something with problems on these. If it's TPI though, he's pulling your crank!
Your car has a MAP only.
[This message has been edited by JoelOl75 (edited February 01, 2001).]
Old Feb 3, 2001 | 05:13 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
It depends, what year is your L98 from?
If it's 90-92, it's not a mass-air setup... it only has a MAP sensor.. if it's 85-89, then it's a mass-air setup.. although I'm not sure if those had a MAP sensor also, or just a MAF sensor.
Old Feb 3, 2001 | 06:14 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Like many of the others replied, it depends on what year your car is. If its 90-92, you have a MAP sensor only. If its 85-89, it has a Mass Air Flow sensor only. 3rd gen f-bodies never had both. Why do you ask about the MAP sensor? Realisticly, the MAP sensor is one of the more reliable sensors, and if the so called "mechanic" says its bad just becuase of a code 33 or so, then you need to move on. Most clueless people think that if a code is set, then that component is bad. Thats where places like AutoZone make alot of there money. You have good instincts to feel ripped off, because it sounds like you are. Take it elsewhere.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
