Will My Gauges Still Work After Motor Swap.
Ok Heres My Bogle... I have an 89 2.8 MPFI FireBird. I am Swapping in a Carbed L98(I know Rip on me if ya want to) I want to keep my Stock Gauge cluster If i can. Im also swapping in an older TH350 Tranny So I dont know If my Speedo Will Still work. I also dont know how much of the existing wiring harness I can remove without messing up my Gauges.... Im trying to clean things up under the hood as much as possible.
Any Help Will Greatly Be Appreciated...
If my gauges Wont work with the swap What Will I need??
JJ
*89 TTA 31K miles
*89 TTA Indy Pace car 33 miles (no not a typo)
*89 2.8 liter TTA Replica 106K miles still runs strong
*91 L98 TA convertible 46K miles
*86 TA new to my Family (in restoration)
JJ
*89 TTA 31K miles
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
You will probably need some new stuff for the speedo but all the other guages should work if you use the right sensors - ie coolant, voltage, oil pressure etc.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, flow tech headers on the way,
engine swap and 4th gen seats in the works...
Ghettobird52
Jul 5, 2024 11:18 PM
