Fuel and Volt gauge
Old Feb 6, 2001 | 02:57 PM
IROCRULZ's Avatar
Fuel and Volt gauge
Ok, My volt gauge does not work at all and my Fuel gauge takes forever to show the level of gas in the car. I replaced the whole instrument cluster with a new one and both gauges worked when when they were hooked up with out the cluster screwed in or steering wheel bolted back up. After I got everything put back together the same problem came back. Volt gauge not working and fuel gauge slowly reading the level of gas.
Does this sound like a short or is this a common problem.
My car is an 89 IROC 305 TBI. The only electrics are door locks and hatch realease.
Any suggestions will be greatly appreciated.
Phil
Old Feb 7, 2001 | 05:35 PM
IROCRULZ's Avatar
Anybody have any ideas? I cannot find a short anywhere.
Phil
89, 5.0 TBI, Bare bones IROC.
Old Feb 8, 2001 | 01:35 PM
Biochem's Avatar
Car: 2002 SOM z28
I don't know that this is any help, but my volt meter never worked. I have no real need for it, and never looked into why it wasn't working.
My stock gas gauge would read way over F, until it got to about 1/2 tank, then it would drop and read normally. My new Autometer gauge does exactly the same thing. It might be the sender in the tank or the connection may be gunked up and causeing problems... it works on resistance.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Feb 8, 2001 | 07:04 PM
IROCRULZ's Avatar
Now Neither of the gauges are working. The volt gauge is pegged to the bottom and the gas gauge is pegged to the top. I have taken the dash apart and can't seem to find a short any where. I guess I will need to take it in and have it diagnosed.
Phil
Old Feb 9, 2001 | 07:33 AM
Biochem's Avatar
Car: 2002 SOM z28
Actually, hold out a few more days. I'm serious about this, the gas gauge doesn't act normally after you pull it out and put it back in at first. It may sound wierd, I know. And you might want to have a gallon of gas handy, but others may back me up too on this one. Almost like it has to learn again once it's back in...
Old Feb 9, 2001 | 11:15 AM
IROCRULZ's Avatar
Ok, I will give it a shot.
Phil
Ghettobird52
Jul 5, 2024 11:18 PM
justin57
Aug 20, 2015 07:05 PM
R3500
Aug 17, 2015 12:16 PM
