Not starting, electrical help needed...
Old Feb 10, 2001 | 05:19 PM
RenoLB8's Avatar
I had to jump it last night, and it started up, ran it for a while, then turned it off and started it again just to make sure it was alright, kept it running for a bit, but then today, once again, the voltmeter is bottomed out. Can anybody possibly tell me what's causing this? No accessories were on, I checked all my wiring for extras (fan switch, amp, disc changer, etc) and nothing's grounding out. This is easily the most frustrating problem I've ever had. HELP!
-Reno
Old Feb 11, 2001 | 03:42 PM
The ODB's Avatar
pull gound cable off your battery.
run test light between negative battery post and the end of your ground cable.
make sure everything electrical on your car is OFF.. don't forget interior lights & hood light.
If the test light comes on then you likely have a short-to-ground and must find it.
If the test light does nothing then there is NO short at all. Your battery is likely bad.
good luck
ODB
Old Feb 11, 2001 | 04:34 PM
RenoLB8's Avatar
you sir, are a genius. THANKYOU!!!!!
-Reno
Orr89RocZ
Apr 25, 2016 08:28 AM
Ikes 91Z
Dec 9, 2015 03:49 PM
TheExaminer
Aug 19, 2015 10:07 PM
mizz0313
Aug 12, 2015 06:45 AM
