Autometer Air/Fuel Gauge help
Old Feb 10, 2001 | 12:55 AM
Super Phil's Avatar
I bought an Autometer Air/Fuel Mixture gauge from my friend, and wanted to hook it up with the O2 sensor on my 88 GTA. My friend never had the gague hooked up in his car, and he doesn't have instructions either. Neither of us knows how to hook the gauge up properly.
Have any of you ever hooked one of these up?? If so, could you post instructions on how to do it? Or e-mail me??
Thanks,
Phil
Old Feb 10, 2001 | 07:23 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Phil,
I tried to scan my instructions for you but my scanner is a piece of crap and decided not to work for me today. But I will tell you exactly what it says for the wiring.
"Red wire: Connect to a fused (5 amp) and switched 12V positive source that is turned on and off with the ignition switch"
"Black wire: Connect to good engine ground"
"Violet wire: Connect to oxygen sensor signal wire. Connect to vehicle wiring harness, not oxygen sensor since some oxygen sensors use shielded wire."
The black and red are simple, what they are saying about the violet wire is to splice into the oxygen sensor signal wire which goes to your ECM, located under the dash board, and NOT to splice directly to the sensor wire. It is actually quite simple to find because the signal wire to your ECM is also violet. If you have any problems let me know.
Also if you want I can photocopy the instructions and mail (snail mail) them to you if you are interested.
Bill
Old Feb 10, 2001 | 09:29 PM
Super Phil's Avatar
Ah Bill,
Thanks so much for the info. I really appreciate it. I'll just print out what you wrote in your post, and see if that works. If it doesn't, I may need a copy of your instructions.
Thanks a lot!
Phil
Old Feb 12, 2001 | 06:32 AM
theformula's Avatar
I ran the violet from behind the A-pillar, under the windshield(sorta) and spliced into the O2 that way.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN93, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP headers & catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Feb 14, 2001 | 09:51 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The gauge works better if you splice into the O2 wire at the ECM. I found that the gauge doesn't fluctuate as wildly using that method.
Old Feb 15, 2001 | 02:08 PM
Blade's Avatar
Getting mine today! I can't wait to get it installed! hehe
92 Z28 5.7
Ported stock heads, XR270HR-10 cam, TES headers
Crane AFPR, Flowmaster catback, MSD ignition
#24 SVO injectors, 1LE aluminum driveshaft.
Best ET 13.3@107 mph
Click here to see my car at Truspeed.org
Check out Truspeed
Check out the Bin Archive
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
Luigytico09
Oct 1, 2015 08:46 AM
Gordonr1973
Sep 29, 2015 11:59 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
