How to test ground?
Car: '00 Chevrolet Corvette
How to test ground?
Use the DC-voltage setting on a digital Volt/ohm meter. Red lead goes to 12V source like the battery + ,
black lead goes to wire coming from ECM. If the wire is being grounded then you will read battery voltage on the meter.
ODB
ODB
Car: 88 Firebird WS6
A better method is to set a digital VOM to the lowest DC setting and probe the ground (while hooked up) with one and put the other probe on the best possible ground you can. If you read more than .02v than the ground is bad.
another appoach is to set your DVM to the lowest resistance setting and measure the resistance between a known good ground and the ground point on the ECU. Also check to see if there are any other grounds on the ECU. If so disconnect that ground and recheck the first test
Car: Take
Engine: Your
Transmission: Pick
Joel has it. It is called "voltage drop". You can have O.O resistance in a wire, but when you apply voltage, it can become open, like most poor grounds do. When you perform a voltage drop, the circuit is loaded, and you are measuring how much voltage is "bypassing" the ground through the multimeter. Really, .05V is the max. It If you are checking ECM grounds, put the ECM is diagnostic mode (jump pins A&B) to turn the cooling fans on, this helps load the circuit.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
[This message has been edited by GMTech (edited February 15, 2001).]
South East Thirdgen
Savannah, GA
'87 Trans Am
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
