ANYONE USING ACCEL 300+ IGNITION?
Old Feb 16, 2001 | 01:43 PM
irocdaddy's Avatar
Car: 89 iroc,2012 eco 150,roadglide
Engine: zz4
Transmission: t56
I THINK I MAY HAVE INSTALLED MINE WRONG. MY CAR IS TPI WITH REMOTE COIL. THE DIRECTIONS SAY I CAN INSTALL IT WITH OR WITH OUT THE MODULE IN THE DISTRIBUTER. WHICH IS THE RIGHT WAY?
89 iroc,zz4/700r4/3:70 gears/koni yellows/herb adams bars/and alot of other crap to make it work!
Old Feb 16, 2001 | 09:14 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
it doesnt matter which way you do it
either way you are bypasing the module.
just read the instructions and itll tell you that either way is fine.
Old Feb 16, 2001 | 10:04 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You need to hook it up USING the module or the computer will not be able to control spark timing.
The distibuter pickup triggers the module which is timed by the ecm to trigger the coil.
Using an aftermarket box the pickup triggers the module which is timed by the ecm which triggers the aftermarket box to trigger the coil.
Bypass the module and you will be running locked-out timing and require a timing computer anyway for street driving. The factory ecm does a better job of controlling timing anyway (If PROMmed right) giving best power and gas mileage.
[This message has been edited by JoelOl75 (edited February 16, 2001).]
Old Feb 17, 2001 | 05:24 PM
irocdaddy's Avatar
Engine: zz4
Transmission: t56
THANKS GUYS. i WILL CHECK IT OUT.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
efiguy
Sep 27, 2015 01:30 PM
