Turn Signals from He!!
Old Feb 10, 2001 | 01:10 PM
84Berlinetta305's Avatar
Ok, on my 84 Berlinetta, the turn signal went out a couple of months ago. Well, I took off the pod that it is mounted on, and it is all computer chip crap. So, I got the wires that went to the signal and hooked them up to a switch on the side of the pod for the signals. Now, my turn signals will not come on when my lights are on. Does anyone know what might be going on?
Old Feb 14, 2001 | 07:27 PM
Anybody have any ideas?
Old Feb 16, 2001 | 12:06 AM
anarquia's Avatar
It's sounds the same as my '89 formula's problem(note: i said problem, i also need help) my turn signals work but drivers side doesn't light up with head lights.
Old Feb 17, 2001 | 11:51 PM
bullfrawg's Avatar
are you saying you took the guage cluster out? If so are you saying the light went out on the dash? if so try replacing the bulb and clean the copper contacts with a pencil eraser. And were you cut the wires is why you lights don't work anymore.
Old Feb 18, 2001 | 06:20 PM
The thing is, it i a Berlinetta, so there is no column turnsignal switch. All the lights are where the light switch is on a regular Camaro, but they are buttons instead of a pull out thing, and the trunsignal is also there, and it is just a little switch that you move up and down. Well, the witch went out, and when I took off the pod to see how to fix it, it was just a bunch of computer chip stuff. I found which wires go to the signal switch, and hot wired them to another switch. thi works fin, except when the lights are on.
Old Jan 19, 2010 | 07:54 PM
RonnHII's Avatar
Re: Turn Signals from He!!
I also have the same problem with my 84 Berli. By chance does anyone know of an OEM parts manufacturer, or even an aftermarket parts company that makes new switches for these rare beauty's. Or if there is a way of fixing this without a degree in computer science ?
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
