Will gauges work after computer removed?
Old Feb 15, 2001 | 09:22 PM
Superblue87Formula's Avatar
I am doing a carb swap and I removed the ecm and all related wires. I still have the wiring harness that comes out the drivers side (has starter and sensor wires on it) are all my gauges going to work? As far as I can tell the oil, temp, volt, and fuel are ecm independant right? the tach will obviously need wired to my new distributor, but what about the speedo?
1987 Formula 350, headman hedders, Accel supercoil, cap, rotor.
MAF screens removed. 160 degree stat and manual fan switch.
Best ET: 14.745@91.317mph-Stock
Best ET: 14.418@95.51 mph-Modded
Ridiculed Founder of the Traction Impaired Crew
Old Feb 15, 2001 | 10:04 PM
The ODB's Avatar
Yes, most of them will work the same as before. Don't you have a speedometer cable to run your speedo? you would see it coming through the firewall right behind the speedometer.
You should have nothing to worry about.
ODB
Old Feb 16, 2001 | 07:10 AM
no, I have an electronic speedo..
Old Feb 16, 2001 | 10:38 AM
The ODB's Avatar
have to try it and see. If not then a good speedo shop or cruise-control installer will hook you up with what you need.
Old Feb 19, 2001 | 09:27 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The speed buffer is a separate (yellow) box from the ECM. If you keep the speed buffer connected & remove the ECM, the speedo should continue to work.
Tim
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
justin57
Aug 20, 2015 07:05 PM
Street Lethal
Aug 13, 2015 08:28 PM
3rdgenparts
Aug 8, 2015 07:09 PM
