PUSH BUTTON STARTER?
Old Feb 15, 2001 | 01:26 PM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
MY girl friend lost tbe one and only ignition key to my car. it has the infamous passkey. the locksmith wants 250 dollas. i cannot afford that. and i am going home to visit family tomorrow. 500 miles away. i need the car tomorrow. i have the door key. alarm chirper. but no ignition key...can someone tell me how to go around the ignition all together and just push button start it? thank you. pleez help. dealer cant make a key without another one to copy from.
thanks
rick
Rick
90 Camaro RS 305 TBI
400 small block, Hooker 1 3/4 LTs, Random Tech Cat, Hooker aero chamber cat back on the way!!
TH700-R4 with Trans-Go shift kit (corvette servo here...but not installed yet)
MacEwen Motorsports White Gauge Overlays
14" K&N X-Stream Open Element
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
http://www.geocities.com/esvalenz
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
"Just because I've done it, doesn't mean I knew what I was doing!" - Me
Old Feb 16, 2001 | 12:27 AM
Car: 90 Camaro RS
Engine: 305 TBI
ok...i got a mechanical key cut...20 bucks. but no passkey in it. now can i rig a switch....or do i have to have the passkey in it. (the mechanical key will turn to ON) but not start it.
Old Feb 16, 2001 | 02:35 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
piece of cake dude: measure the ohms on the chip in your key (mine was 640) and buy an identical resistor from radio shack (pack of five, about $.50) drop the panel under your steering column and find the two tiny yellow wires that plug into a harness - can miss them. cut off the harness on the end that does not go to the column, and solder a resistor you bought between the two. done.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: GMPP 8MM wires, Accel cap&rotor, AC Plugs
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension/Drivetrain: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, All synthetics, Flexlite Transmission cooler
On the way: flow tech headers, alum. driveshaft
"You say turn that volume down? Well all I gotta say to you is NO, no no no no...
I want to Rock - ROCK - I want to Rock - ROCK - I want to Rock with you..."
Old Feb 16, 2001 | 02:41 AM
Car: 90 Camaro RS
Engine: 305 TBI
THERE IS NO RESISTOR IN MY KEY...ITS JUST THE MECHANICAL KEY. NO CHIP. THAT IS MY PROBLEM. THANKS ANYWAYS. I TRIED TO PUT KEY IN ON POSITION AND JUMP THE STARTER....NO SUCH LUCK. IT TURNS OVER BUT WONT START
Old Feb 16, 2001 | 03:29 AM
Jza's Avatar
Jza
LOL. The dude just said he lost his key! I'm sorry, that was just too funny.
You can also replace the chip in the computer with one that doesn't have the VATS stuff on it. But since you mentioned you were going somewhere today, I guess you don't have time to get one.
There are I think 12 or 15 different resistor values (someone here could say for sure). You could get resistors of each value and try one by one until you find the right one. There was a post a couple years back that listed all the values. Sorry I couldn't help more.
Old Feb 16, 2001 | 03:36 AM
Car: 90 Camaro RS
Engine: 305 TBI
thanks JZA. yeah i think its 15.
i might just have to do that.
the vats disables hte injectors...so hte starter jumping theory didnt work. well...i dont know what to do.
also...see my post in tech.
Old Feb 17, 2001 | 01:45 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Maybe we can get a list up of the different values of resistors for further vats problems
so far we have 2 of the 15,
mine was 680 ohm and he said his was 640 so only 13 to go.
Old Feb 19, 2001 | 09:43 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
Another solution would be to purchase a new VATS module & key. The VATS module programs itself to use whatever resistor value it sees the first time it is powered up.
Tim
RedLeader289
May 28, 2019 01:47 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
