V8 tach into a V6 car?
Old Feb 18, 2001 | 11:15 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
can i put a tach out of a V8 car in a V6. i know the V6 wont work a V8(car is v6 now a V8). does the tach go through the ECM? or is it independent like the gauges? if i can swap them out, how do i go about it? thanks. i posted earlier but no replies.
Wide Open Till You See God...Then Brake
Old Feb 19, 2001 | 10:08 AM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
If a V8 drives a V6 tach, the tach will read 25% high. With a V8, there are 4 pulses per revolution of the crank from the ignition system, while a V6 outputs only 3 pulses per revolution.
Tim
Old Feb 19, 2001 | 11:38 AM
LilJayV10's Avatar
Engine: 406 Roller
is there anyway to change this so i can put the v8 tach in?
Old Feb 20, 2001 | 04:54 PM
You could probably modify the tach circuit to recalibrate the frequency to voltage converter for a different number of cylinders, but I have never actually tried to do it. Probably easier to get a tach for a V6.
Tim
Old Feb 21, 2001 | 02:50 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
The tach has nothing to do with the ECM. It has a signal wire that goes to the distributor. You will need either an aftermarket, or a V6 tach to go with a V6 engine.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
Old Feb 21, 2001 | 06:44 AM
ausrs's Avatar
making a 6 cyl tach work on an 8 ...have had that done
find an instrument fitter they can re calibrate it to work with whatever motor you want !
$750 L98
Feb 1, 2025 02:25 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
RedLeader289
Sep 23, 2015 06:50 AM
Racerx974
Sep 19, 2015 10:16 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
