Driver's side battery questions?
Old Feb 16, 2001 | 10:46 AM
MikeS's Avatar
Ok guys, the battery tray on the passenger side of my car is rusted through pretty badly. So I want to move the battery to the tray on the driver's side this weekend. I know that I will have to relocate the charcoal canister and such, but really want to know about the battery cables? Anybody who has done this, or who has a car set up like this from the factory....would you happen to know how long your battery cables are and how they are routed? I would appreciate as many details as I can get. Hopefully that will make sure I do this fix right.
Old Feb 16, 2001 | 09:42 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Firebirds have the bat on the drivers side and the ground runs to the block and the + makes a haphazerdly mile long stretch to the starter. I moved mine to the trunk. Then you don't have to worry about move charcoal and junk. That stuff should be moved to a garbage can instead.
Old Feb 17, 2001 | 12:50 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
<font face="Verdana, Arial" size="2">Originally posted by JoelOl75:
Firebirds have the bat on the drivers side and the ground runs to the block and the + makes a haphazerdly mile long stretch to the starter. </font>
Both of mine (83 and 99) and all my customers Firebirds aren't on the drivers side.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 17, 2001 | 08:16 AM
Jza's Avatar
Jza
Your sig has a 4th gen 'bird, but I can't explain your customers' cars unless they are too. All the thirdgen 'birds I've seen have the battery on the driver's side, and the airbox on the passenger side.
Old Feb 17, 2001 | 08:53 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Carbed 3rdgens have them on the passenger side. TBI I think also.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors, Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
--&gt;14.97 @ 94.9 MPH&lt;--
'97 Bonneville SSE
Old Feb 17, 2001 | 10:32 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
My 4th gen has it on the pass. side.
My 83 T/A crossfire had it on the pass. side (RIP)
My GM manual shows it on the pass side for V8s and V6s exept for the 2.5L fours.
And my cusomers 3rd gen T/As and Camaros have it on the pass side.
I'm not saying they don't exist, I've just never seen one.
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
GO #3
Old Feb 18, 2001 | 07:41 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
my 89 bird, V6, has the battery on the drivers side, and about 13 feet of battery cable
Wide Open Till You See God...Then Brake
Old Feb 18, 2001 | 11:28 PM
MikeS's Avatar
Well, the swap is done. I had to remove the charcoal canister (would have remounted it on the pass side, but it was rusted away) and get a new positive cable. 62" cable cost like seventeen bucks, but i'm happy with how it turned out.
Old Feb 21, 2001 | 08:28 AM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
91 GTA (350 tpi) battery is also located on the drivers side with the air intake located on the passengers side...
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
redmaroz
Aug 16, 2015 11:40 PM
timonator
Aug 11, 2015 09:56 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
