no codes, no 12's on the ecm
Old Feb 16, 2001 | 10:36 AM
leirch's Avatar
Guys, i posted something similar to this a few days ago.
The service light will not work(for diagonostic mode) or turn off at all. I checked all of the connections and even tried different memcal/prom combos. When the car is running , the service light is on constat. When trying to go to diagnostic mode, the light stays on constant still. Will not flash at all or do anything.
Bad ECM right?
I'm going to replace it soon, just want to know if there is anything i can check to make sure?
Brendan
1987 IROC-Z L98 350 SuperRam, Edelbrock Performer 6085 Aluminum Heads, LPE RollerCam 219/219, Crane Gold Race 1.6RR, TF 1 pc Moly Pushrods, Underdrive Pulleys, Edelbrock TPI High Flow Base Manifold, Accel 58mm TB, ADS 24#, Crane AFPR, K&N, Edelbrock TES Headers, Catco Hi Flow Cat, 3" Borla Cat-Back, Accel Cap & Rotor, MSD 8.5mm, MSD 6AL Ignition, MSD Blaster 2 Ignition Coil, Hayes Clutch, 1LE Aluminum DS, 94' Z28 Disk Rear, Wilwood Adjustable Proportioning Valve, Torsen Series 3 Posi Carrier, Precision 3.73 Gears, Southside Machine Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Feb 16, 2001 | 09:38 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
Maybe the SES light output from the computer is shorted to ground. Or the computer is shot. Try cutting the ses light output wire and run it to a small 12v bulb with the other side to + and see if it works. Otherwise bad memcal or ecm.
Old Feb 17, 2001 | 11:44 PM
bullfrawg's Avatar
sounds like the computer or it may be the guage cluster itself. On the back it will have a plastic/copper/plastic sheet. This sheet contacts all lights and guages in the dash. IF your car still runs fine it may be the contacts on this sheet have shorted or have become corroded. But usually when this happens the light stops working.
Old Feb 20, 2001 | 11:34 PM
Keith5's Avatar
Car: C1500
Isn't there a code for a bad ECM?
Old Feb 21, 2001 | 03:24 PM
Tim Burgess's Avatar
Car: '92 Z28; Dk Teal; Her Pkg
Transmission: Richmond 6 Spd
Axle/Gears: Moser 9", Detroit Locker, 3.70
The earlier year F-body models used a light driver module to switch the current in the SES or check engine light. I'm not sure in what year GM changed over to the ECM driving the light directly. If you have one, the light driver module may be the problem, as well.
Tim
Old Feb 21, 2001 | 03:50 PM
leirch's Avatar
Everybody that replied, thanks.
I think i've been able to find out whats going on. TPI383 from the boards here sent me a nice diagram to work with to find out the problem.
Turns out that while having the ignition on the light was on, while having the car on, the light was on. While having the ignition on and computer unplugged the light was off. So the only thing that could possbily be wrong would be the computer. If the light was still on while the computer was unplugged with the ignition on then the SES light wire would have been short to ground.
Turns out that my luck is showing a bad computer.
Brendan
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
eustodp
Sep 20, 2015 05:09 PM
Reese-J
Sep 14, 2015 02:43 PM
RyanJB
Sep 2, 2015 01:27 PM
