lighters
Old Jun 25, 2002 | 05:19 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
lighters
is there some common flaw in gm cig lighters? In the two firebirds ive owned and my friends firebird and his 96 bonneville, there have been a total of 0 working cig lighters and all cars were checked for blown fuses, anything anyone?
Old Jun 25, 2002 | 07:34 PM
Tonyrodz's Avatar
Transmission: auto
I've owned over a dozen GM's and never had a problem w/a lighter. Did you pull the receptacle apart to make sure the ground and pwr wires are connected? That's the only thing I can think of.
Old Jun 26, 2002 | 01:13 AM
1a12's Avatar
if the lighter part is corroded with ashes, or whatever, it won't make good contact and won't heat up. Also make sure that the inside well is not corroded as well. this is the only problem i had with mine.
ZZ3Astro
Aug 13, 2019 12:57 AM
Moore89
Aug 24, 2015 07:06 PM
crazynights
Aug 21, 2015 06:53 AM
Phil0rg
Jul 22, 2001 10:26 PM
Maverick13
Mar 23, 2001 02:05 PM
