problem w/ power window wiring
I have this problem with my power windows. Some times they work and sometimes they do not. Sometimes one side will work and the other will not. Also when I was pushing the window button the volt gauge and the RMPs would dim down and the needles would move, and the cd player would dim down also. I noticed that the wires to the window button(this is the drivers side) would get real hot; just the blue wire. I know it is not the power window motor or the window button, but it is the wiring for it all. I am assuming that it is just a bad connection or a bare wire is touching something. If any of you have had this problem let me know, just to make things go alittle easier. thanks
