HELP with instaling MSD coil and ingnition amp box
Old Jun 26, 2002 | 04:10 PM
Don_89Iroc's Avatar
i just got an MSD coil and im told it wont fit in the stock position, so where can i mount it??? and also im getting an MSG ingniton amplifier soon so i was wondering a good place bolt it into the engine comp. also how hard is it too hook these things up?? Thanks -Don
Old Jun 28, 2002 | 12:24 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
If you got the correct coil, all you have to do is remove the rivets holding the factory coil in the bracket, bolt in the MSD coil, and reinstall it on the manifold.
As far as the box, here's where I put mine. I made a bracket out of 1/8" sheet aluminum. MSD makes a harness that is pretty much a pull and plug in thing, costs about $20 I think, well worth it. Call 'em and tell them what you have.
Pic:
Attached Thumbnails HELP with instaling MSD coil and ingnition amp box-msd-box-pic-2.jpg
Old Jun 28, 2002 | 02:15 PM
Don_89Iroc's Avatar
Thanks for the reply, so the coil bolts into where the stock coil goes kewl, as for the MSD amp ive seen people who have bolted it to the firewall, im also have a strut tower brace i will be putting on, do you think that may interfere with the MSD box, if i would put it in the same place you put yours, looks like it could be close
Old Jul 1, 2002 | 05:55 AM
ebmiller88's Avatar
Here's a shot of my Jamex STB installed. No problem with my box location.
Attached Thumbnails HELP with instaling MSD coil and ingnition amp box-irocstb2.jpg
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
toronto formula
Nov 10, 2015 06:17 AM
TheExaminer
Aug 25, 2015 07:34 PM
midias
Aug 15, 2015 05:07 PM
